Сьогодні: 06 листопада 2026, 02:56
ПовідомленняДодано: 19 жовтня 2026, 12:17
З нами з: 19 жовтня 2026, 09:35
The highly anticipated PvE mode for ARC Raiders has finally entered its testing phase. The PvE beta test will run from October 13th to October 20th, giving you one week to experience this unique mode.
In this mode, you can focus on battling ARC enemies without the constant threat of encountering other players. However, in this safer environment, the value of loot and the matchmaking mechanics have been adjusted accordingly.
The most significant change is that player-to-player damage is disabled in PvE sessions. Raiders can explore, gather resources, and cooperate without being directly attacked by other players.
However, PvE does not remove every danger. ARC enemies remain hostile, and players must still manage their resources and plan successful extractions.
Several other mechanics also differ from the standard experience:
  • Throwable items: Stun and fire throwables cannot affect other Raiders.
  • Physical interactions: Items such as barricades and ziplines continue to function normally.
  • Squad matchmaking: Solos, Duos, and Trios may appear in the same session because squad separation is not prioritized.
  • Map restrictions: Night Raid, Locked Gate, Hidden Bunker, Frigate, and Redirection are unavailable in PvE matchmaking during the test.
  • Downed players: ARC enemies may reacquire downed Raiders after an eight-second grace period if they detect movement.
Since you no longer face threats from other players, the total value of loot in PvE mode is lower.
For players seeking specific gear, crafting materials, or rare blueprints, this means you may need to spend more time searching for the resources required to build your ideal loadout. You might need to run the map multiple times, and the randomized loot drops may not always meet your specific needs.
Therefore, prioritize collecting materials that align with your crafting plans, identify which gear upgrades are most critical, and avoid filling your backpack with items that serve no purpose for your current objectives.
If you prefer not to spend excessive time grinding for resources, buying ARC Raiders items directly is a very sensible option. This streamlines the search process, allowing you to assemble your desired gear more quickly—freeing up time for completing missions, exploring the world, or engaging in combat against ARC’s mechanical foes.
Acquiring and developing blueprints is also a key aspect of the game. Valuable crafting recipes expand your equipment options and boost your combat effectiveness. Buying ARC Raiders blueprints offers a more efficient way to reach specific crafting goals, sparing you from an over-reliance on repetitive scavenging and the risk of losing everything should an extraction go wrong.
So, if you’re looking for a stress-free expedition with your teammates, the PvE mode in ARC Raiders is definitely worth a try. While the lower quality of loot drops might make the experience feel less rewarding, buying ARC Raiders items or blueprints can help you maintain your combat effectiveness—enabling you to easily defeat ARC enemies and truly shine in battle.
